QUESTION; EST CE QUE JE PEUX MONTER LE COUVERCLE ARRIÉRE DU 400 SUR LE BLOC DU 500 MISE À PART LE JOINT DU DIT COUVERCLE, Y A T'IL BESOIN D'AUTRE PIÉCE
![Confus :?](./images/smilies/uhhh.gif)
